Heatslave lock out - please help !!
Still at it Graeme :confused:
To test the solenoid coil, put a multi meter set to resistance across the 2 lower terminals and you should get a reading.
To see if its actually magnetising, place some steel tool on the coil and you should feel the magnetic pull.
(This one is courtesy of the genuine experts on here...)!
John :)
John,
Thanks for taking the time to answer.
I've re-set the lockout switch with the solenoid valve disconnected and put a screwdriver in the hole, I can't feel any magnetic pull.
Does that suggest a faulty solenoid ?
Can you put a magnet on the "thingy" that the solenoid magnetises to get some oil flow through it ?
Hi Graeme
You should feel some sort of magnetic pull, but only when the control box tells the oil valve to open i.e about 6 sec after the fan starts up.
It sounds like the solenoid coil could be faulty - its common enough - and maybe the oil seen at the nozzle was kerosene just being blown out - who knows?
Anyway, its a Danfoss coil, number 071N0051 (nearly certain) and they cost around £22.
John :)
Hello,
Just an update for today,
I replaced the Danfoss oil pump, as it leaked a bit anyway, and with it came a new solenoid as I'm sure you would know.
Once it was all back together I fired her back up and away she she went with not much bleeding at all.
Has been running ok for a while now, but when I switched it off there was quite a bit of smoke / vapour (not sure which ?) coming out of behind the control panel. Hope it's just a bit of oil that I spilt vapourising ??
So just for anyone else in the same situation, I feel it was the solenoid on top of the oil pump not energising. I checked the voltage to it and it was about 74 volts. However, when I tried to energise it, there was no magnetic field generated when I put a screwriver in it, so there was no oil getting to the burner for the electrodes to light.
Hopefully, this will be the end of my latest hassle with a very unreliable boiler.
A very big thank you to all the people that contributed to my plight, in particular John (Burnerman) :D , and a big thank you to all the previous posts, as by reading them I was able to eliminate most things.
Now I need to get it set up by an engineer.
I'm never this lucky, so will post again in a couple of days probably with the house burnt down :oops:
Delighted that you're up and running again :p
There should be no visible smoke at the (balanced) flue - in fact the fumes shouldn't be particularly acrid to smell...sort of 'dampish'. Some condensation fume is normal.
Fumes inside the boiler casing? They will probably go, but you can fit a foam type gasket around the blast tube before shoving the burner back in the 'ole. Keep a nose out for this one.
Ideally you'll still need to get the thing set up by someone who has a smoke pump and a flue gas analyser. CO2 ideally around 10.5%.
Initially, the problem has been oil droplets just being blown out of the nozzle or the oil valve not opening right in the pump - which threw us off course a little.
I have noticed that these BFP41 pumps can leak a bit - usually around the pressure adjustment screw - usually when I don't have one in stock - but turning the screw forwards and back gets them sealing again.
Best wishes and well done! I'll dodge the e-blows but I quite like these burners.....
Cheers John :D
Yes it needs setting up for definate, there is soot on the external flue grill already :(
Not sure whether to buy an oil pressure tester just to set the pump pressure, as the boiler was only serviced a couple of months ago. Or whether to leave it to a proffessional to do the full set up.
Just wondering if the other values would remain the same if they haven't been touched ??
You really need a pressure gauge (1/8 BSP) and a manifold to set things up - the pump is set at 10 bar at the factory which is too high for your burner. Plumbers merchants do the gauge and manifold for around £30.
The gauge screws (with ptfe tape) into the port marked 'P' on the pump front.
These burners are sensitive to the air door setting - just one number out of adjustment gives a soot reading of 3! Its only a FGA can really sort that one, but the pump pressure is very important too.
John :)
Remember you put an old nozzle back in, these can vary in output by + / - 15% or it may have been a duff one so i would get it sorted as soon as poss as it wont take very long befroe your boiler is packed full of soot, messy job!
