Heavy Glass Shower Screen
14 Jul 2004
I have just fitted one of those P-shaped shower baths and am about to fit the curved glass screen above the bath. The screen will be fitted to a tiled wall which is plastered brick behind.
The 3 raw plugs and screws supplied seem incredibly puny to hold such a weight - I'd say they were around 1 1/2 inches long max.
An easy question - are these really up to the job (as the load is spread over three of them) or do I need something more substantial?
Theres nothing stopping you from using larger fixings if you are worried.
Go for it:cool:
If you do use the supplied plugs make sure you push then beyond the tiles and plaster so they are fully in the brickwork, may need longer screws which should be stainless steel or brass. Is it a bathstore one as the Ideal standard one usually has decent fixings.
Jason
It's a Jacuzzi one from Homebase.
Annoyingly they also predrilled (very large) tap holes in the back corner. Consequently every time you turn the shower on, it's impossible to get out of the way without getting soaked! It was also a pain trying to waterproof the large gaps around the tap tails - especially as the bath had already been fixed by the time I had discovered water from the shower went straight through, making it impossible to reach the furthest away tap.
Typically my existing pipework would also have been perfect for mounting the taps in the obvious place in the centre......
Why O why is this plumbing lark never easy!!
