I have a 40kg double bank radiator to fit on to a wall that I've now realised is all plasterboard and with no stud for the position it needs to go, underneath a straight section of bay window.
I had bought some of these:
https://www.toolstation.com/fischer-radiator-fixing-set/p88335
On the packet though they state a max weight of 20kg. There will be 8 fittings in total, to fit each of the 4 brackets.
Does the 20kg mean per fitting or the whole weight regardless of number of fittings?
I've since found some Grippit fittings that go up to 113kg but require quite a large hole drilling.
https://www.screwfix.com/p/gripit-plasterboard-fixing-25-x-14mm-8-pack/682gk
I think my options are, easiest to hardest:
1) Go with the fittings I've already got
2) Get the Grippit fittings
3) Attach plywood to the nearest studs spanning the radiator and down to the floor (refitting skirting over it). Being under a bay window it will be relatively seamless
4) Hack out 2 horizontal strips where the brackets will go and fit 2 thick wooden battens spanning the two studs, then replace the board, make good and fit the brackets
5) Remove the entire piece of plaster board, fit battens as required and including floor joist support, fit new sheet of plasterboard or reuse old if possible, make good and fit the brackets
Are there any other options? Which is the best for the weight of radiator involved balanced with the amount of hassle?
Any advice appreciated. Thanks.
