Just wondering if anyone has had a fault with the boiler which indicates no gas, middle light on with ones either side flashing. the boiler tries to ignite fan and pump running you can see the spark but boiler doesn't light, it tries a couple of times and then locks out, a new gas valve and flue temp sensor have been fitted but still the same fault!!!
No gas seems to be getting to the burner as the engineer put a lighter through the little window as it was trying to light and nothing!
is there anything else that can be stopping the gas valve letting the gas through???
Please help i cant spend much more in this boiler!!
Cheers Timmy
Cheers Timmy
