Hi all
I have a Baxi Solo 18 HE boiler (heat only) with a gravity fed system
About a week ago I drained down and moved some radiator pipes in the bathroom ready for a new towel radiator. I installed the valves onto the new pipes, shut them off and then refilled the system.
The system worked for about a week but this evening the boiler is giving an error - 1 solid red light and 2 flashing green which according to the front of the case is "no water flow or reverse flow".
I have tried bleeding everything i've found including the pump to no avail. Water not air comes out of everywhere!
I can hear the pump running so that seems to be OK
Both tanks in the loft are full of water
Any ideas of what I should check next?
Thanks in advance
Ben
Thanks in advance
Ben
