Boiler Made is Potterton Puma 100,combi, about 14 years old. My original problem was just the central heating not stable which took about 10 mins to 2 hours to heat up the radiator. Hot water was fine. And it seems using hot water frequently will help the central heating heat up quicker. Then I got Eon to diagnose the problem and was told that pump wasn't circulated properly and need replaced. As I have insurance cover from Halifax, so I then paid extra £100 something to the insurance company to do the job by fitting a new pump and diverter valve. After both parts fitted in, everything seemed to be fine until the engineer close the boiler out case. The boiler went dead. Fuse blown. The engineer tried 4 fuses all got blown in few mins operating. He told me it's PCB faulty and need replacing. Now they cannot find the parts and want me to buy the parts. But I really doubt it's from PCB. Would it be from pump, fan or any wiring problem that cause the fuse blowing. would the incorrect pump fitted that cause the problem? BTW, there is no water leak on PCB.
Any suggestions would be greatly appreciated!!!
