Hi
We've got a worcester bosch 14/19 Cbi installed - about 5 years ago. We've lived at this house for almost 2 years and not had a problem with the boiler until now.
2 weeks ago, in the cold snap, the boiler failed to fire. After leaving it off for a while (5 hours) it then worked fine, lighting up properly. Again, a couple of days ago, coincidentally when another flurry of snow hit London, the boiler failed to fire. This time we haven't been able to get it going and called out staunch and flow, who we've used before to service the boiler and seem pretty good.
After a couple of hours here, the plumber has said that the reason the boiler isn't firing is that the pressure is too low (15) at the boiler. At the meter, which is down the stairs and outside, the pressure is 28. He claims that it's 'probably' due to the size of the pipes and the number of bends. He's suggested that the valve attaching the pipe to the boiler could be replaced, to change the pressure. Partly because the valve is 'old'.
My concerns are - why haven't we had problems before if the problems are with the pipes / valve - it's unlikely (though possible?) that something has started to fail. Should this have been noted at the previous servicing of the boiler? Was it a coincidence that the boiler failed to fire up correctly during the cold snaps? IF the engineer is right, isn't it possible that a new valve may not fix the problem? Could it be a problem with the piping that's developed elsewhere?
Any tips appreciated - for instance could i call transco and say we have a problem with gas pressure?
Thanks in advance!
Thanks in advance!
