Help - can't find replacement window gasket!
19 Jun 2021
Hope some window gurus can help! We just moved into a new place and the window seals are pretty perished on a couple of windows. I have ordered a bunch of samples of replacement e-gaskets from suppliers but can't find anything vaguely similar to what I currently have - pictures attached. One seal supplier has suggested an alternative but it doesn't seem quite so tight a fit and also expensive due to a minimum order of 50m. I wonder if anyone has come across same issues and found a solution / replacement? Thank you.
