Help, got 6.2kw hot plate hob plus a separate 5.5kw oven each needs its own seprate power supply,the CU(45amp)wall switch has a 10mm T&E cable running from it to an 45amp outlet(connection unit)...Too the 45amp oulet connection unit, i have connected 6mm T&E which is from the oven...Which works fine.In the mean time i have left the hob disconected and told the mrs's use the microwave...
Can i connect the hob to this connection unit also...if so what size cable can used
if this is not possible....could u please advise...
ie ring main 30 amp junction box to 13amp switched fused connection unit - 20 amp flex outlet plate???? then to hob??
