Hi
Was taking skiring boards off last night and in the process i made a small hole in the system.
I thought id turned off the central heating valves there are 2 located at the bottom.
I drained the radiator system but the pressure dropped. But when i repressurised it started to leak again as the water must have gone in the pipe
if the valve was closed would the repressurising cause water to go through the pipes.
ps. i looked manual but no joy i wanted to know which way would be close? i did it with a spanner
Stressing now! pressure was 0.1 this morning!
HELP!
HELP!
