Help finding a topic/post
27 Aug 2003
London
Tried every search I can think of....
Someone posted here once showing the results of an experiment to see how much current a dimmed lamp actually took at reduced brightness.
Anyone remember it, know where it is?
Was it actually here Bas?
I thought it was over at the blue room?
This is all I can find:
Does using a dimmer switch reduce the amount of electricty used?
Well, yes it does, but not by as much as you may think. Have a look for yourself.
Notice the lines on the dimmer switch, One is Off, the middle one is 50 % (its halfway between off and on) the last is fully on.
Do observe the reading (in Watts) shown on the display.
View media item 7014 0%
View media item 7015 50%
View media item 7016 100%
Although the dimmer is set to 50% do look at the watts, its not 50% of the total
Found here:http://www.diynot.com/forums/viewtopic.php?t=7553&start=45&postdays=0&postorder=asc&highlight=
EDIT: Though the piccys no longer appear...
