Hello All,
I'm bit of a newbie when it comes to electrics so please take it easy on me
I've had experience in changing ceiling roses to modern fittings around the house, and understand the basics, but I am learning as I go. I am currently trying to replace some old hideous lights in our bathroom. They are the old style spotlights (if you can call them that) which are bulky and really don't suit our modern bathroom.
They look something like this:
http://images.linnlive.com/97DE1640224DDD3FCEEB7153504569B6/85ee331b-93e8-4ea9-bd20-942a907e5e42.jpg
The first fitting is currently wired into a junction box in the attic, which then runs on to the second light. (Just the 2 lights - it's a small bathroom). These lights left a bigger hole than what's needed for modern spotlights, therefore I've purchased a converter to cover the hole as it seemed the easiest way to get a standard GU10 fitting in.
The new light fitting is a downlight converter which is exactly like this:
http://www.litecraft.co.uk/media/ca...ab33525d08d6e5fb8d27136e95/M/2/M20-HCBC_3.jpg
Except it's for a GU10 lampholder not a low voltage therefore no transformer necessary.
What I'm unsure of is how to connect the new fitting? I assume I just remove the existing light from the junction box but how would I wire in the new fitting? There is no cable provided with the new fitting, so I assume I would need to buy a short flex like this:
http://www.ebay.co.uk/itm/All-White...pplies_Electrical_ET&var=&hash=item3a7af3738e
Would I be right in saying I need 3 core? I've not yet been in the attic but I am sure there will be earth present, even though the current fitting doesn't seem to be earthed. Is it just a case of wiring in the new fitting into the junction box in the same way that it's currently wired? And then running the earth from the junction box to the terminal on the new fitting's metal stirrup?
Would greatly appreciate any help/advice.
Thanks,
Craig
Thanks,
Craig
