Help hanging 700 wide wall-hung basin
27 Jan 2004
Hope that somebody can help me (again!) :)
We've bought a Twyfords Pure Energy basin (a badged Keramag 50 by Antonio Citterio).
The basin is intended to be wall hung and has an integral chrome towel rail (not shown on this picture):
The basin is 700mm wide and has 430mm screw hole centres which has meant it's not possible to use any of the basin mounting frames sold in the UK:
Our walls are cinderblock and we were always intending to put up a stud wall to hide the pipes behind as the basin does not even have a semi-pedestal.
We've weighed the basin today and it weighs 34kg and the towel rail another 4kg.
I'm looking for advice on fixing the basin and the size of studs I will need. I have thought about using 25mm ply to fix to as Easi Plan's basin frames use 25mm ply to fix to:
I'm considering use Fischer basin kit but what framing would people recommend? 75mm x 75mm studs (with a hole through one side at one point for the 32mm waste pipe and two other holes for 15mm hot and cold) or bigger? 25mm ply for the basin to fix to or a noggin? If a noggin, what size? What would you use to fix the framing to the cinderblock wall.
You'd think Twyfords would recognise that the screw hole centres are much wider than standard in europe and offer good advice but their suggestion was to ask my builder! If I've got one I'd like to know where they've been hiding whilst I've fitted the kitchen and the rest of the bathroom! :LOL:
