Hello, I recently had a water meter installed outside the flat, after that I started having noises.
I live in a split level flat, only very recently, every time after I flush the toilet or use water on the first floor there's the humming noise coning from the pipe under the kitchen sink, but it's fine when I use water in the kitchen. It also makes the same noise when the boiler is on.
There is a faucet under kitchen sink which I believe connects to the main, there's a lever under bath tub on the first floor. I did turn the main faucet down but it didn't help.
I haven't done any DIY work and I'm not sure whether having the water meter installed can somehow cause this problem or it's just coincidence? Is there anyway to solve the problem? I have to go upstairs when the boiler is no because the noise gives me a bad headache. Please help
