Help Identifying & Replacing Bar Mixer Shower (Photos Included)
20 Apr 2025
Hi all,
Looking for some advice on replacing a shower unit that was already installed when we moved in. It's an exposed thermostatic bar mixer with integrated tap connectors feeding from the rear (through the wall). It has a lower knob for temperature and an upper diverter knob to switch between a handheld and overhead rain shower.
I've attached a few photos of the setup to show the configuration and fittings. (Never come across this type of shower unit with tap connectors and whoever did the pipework.....
Ideally, I'd like to replace it with the same make and model (or a compatible one with the same dimensions and connector setup) to avoid disturbing the tiling or needing a plumber to move pipework.
If anyone recognises the unit or knows of a like-for-like replacement, I'd be super grateful! Also open to full kits if needed, as long as the wall fittings match up.
Cheers in advance!
Using Google lens I found one on baseline restoration ltd Facebook page, however I don't have a Facebook account to look.
