Help - Kitchen Wiring
24 Jun 2008
Hampshire
I'm having a bit of a crisis as I'm having a new kitchen installed in a few weeks but the electrician has let me down and canceled.
I'm planning to get an electrician to do the final connection but until I can find one I figure I can get on and channel out the walls etc myself. There are a few things I'm not sure about though.
- is it acceptable to have horizontal runs between sockets?
- For the oven and under cabinet lights the switches and outlets are not in line , do I have to take the cable down under the floor and across or can I go down and across under the plaster?
- If you can go down and across under the plaster how do you handle the corners?
-Should I be using PVC or metal channeling?
Any help will be much appreciated.
Capping, you are probably refering to.
You can use galvanised steel or plastic, I, and most other prefer to use galv steel as it is easier to pick up with a metal detector :D
This work is notifiable and therefore you cannot just DIY and get an electrician to do the final connection, not in terms of complying with the law.
IF you want to comply, then to DIY then you must notify your council in advance, then they should inspect your work during progress and test it. They won't actually do any of it though - you'll have to connect the final circuits into the CU yourself.
