Hi
we have a gainsborough regent II shower - cold fill heated type.
I noticed that the shower was leaking recently and that this was getting worse.
When it was on it would drip / flow as it got worse from where the shower cable head joined the unit. I put some tape on it and tighten it up - but still it leaked and clearly from inside the unit.
So I disconnected all the electrics and the took the cover off and found 2 things
1)The source of the leak when the shower is turned was under the small heating chamber, through a small nut, this nut is hollow.
When the shower was on water was constantly running out the bottom of this into the shower unit itself. Thankfully this has been hitting the shower head flex and that has been drawing the water out of the unit
2) A little plastic pipe that was loose that I now believe goes under the small heating chamber to direct water out underneath the unit, this I have now re attached to this.
Now when the shower is turned on the water pours out of this small black pipe.
So my questions are.
Firstly how do I stop this leak occuring
Secondly how safe is it to use the shower now, and if its ok how dangerous was it actually while this small black pipe was off and water was inside the unit near the electrics - my very limited knowledge tells me this was not good!
Thanks in advance for any assistance and guidance with this.
Surfergraham
Surfergraham
