I knew that.
Yes, it might be 3-core. Those photocells do require a neutral (and PIRs, which this item obviously isn't, will inevitably always require a neutral).Might be 3-core. Might be a PIR which doesn't need a neutral.
Intriguing - thanks. Unless they contain a battery which charges whilst the load is drawing current (or let a little current flow through the load even when it is 'off'), I can't for the life of me see how they could power the electronics when the load was 'off'! (and, even with that, the battery would eventually go flat if the PIR were never activated - maybe a solar-charged battery?)http://www.discount-electrical.co.uk/product.php/4604/elkay-energyoutdoor-white-2-wire-pir-timer-with-surface-mounted-back-box-ip66-16a-240v(and PIRs, which this item obviously isn't, will inevitably always require a neutral).
There is a fairly simple trick they can use. If you delay turning on the load until the voltage has risen to a few volts, then you can use that to power the electronics (through the load to neutral). The effect would be to reduce the lamp brightness very slightly, though probably not enough for anyone to notice.Unless they contain a battery which charges whilst the load is drawing current (or let a little current flow through the load even when it is 'off'), I can't for the life of me see how they could power the electronics when the load was 'off'!
The standard method/'trick' for getting power for the electronics with '2-wire' devices is to stick a small resistor in series with the load - thereby, as you say, 'stealing' a small amount of the voltage, which thej gets rectified to power the electronics. However, that only works whilst there is current passing through the load. Hence, if the load ever gets 'completely switched off', the electronics would lose their power (and therefore not be able to switch the load back on again), unless there was a battery.There is a fairly simple trick they can use. If you delay turning on the load until the voltage has risen to a few volts, then you can use that to power the electronics (through the load to neutral). The effect would be to reduce the lamp brightness very slightly, though probably not enough for anyone to notice.Unless they contain a battery which charges whilst the load is drawing current (or let a little current flow through the load even when it is 'off'), I can't for the life of me see how they could power the electronics when the load was 'off'!
That makes sense. In the absence of a neutral, there really are only two possibilities - either a battery or else some current flowing through the load even when it is 'off'. However, as I said before, if it's a battery, it will go flat if the PIR rarely, if ever, activates - unless there is a solar charging facility.Havent really looked close but they do have some sort of battery, There is a small dip switch which you have to use to switch it on after installation
Commonly done, which is why it's common for them to be unsuitable for fluorescents, LEDs etc. And why people sometimes report such lamps flashing.or let a little current flow through the load even when it is 'off'
That makes sense, but the one to which you linked says "16 Amp max load regardless of load type including resistive loads and incandescent/fluorescent lighting". If it works 'regardless of load type', I would have thought it would be difficult to arrange for a small current to reliably flow through the (any) load when it was 'off', wouldn't it?Commonly done, which is why it's common for them to be unsuitable for fluorescents, LEDs etc. And why people sometimes report such lamps flashing.or let a little current flow through the load even when it is 'off'
I think you missed what I'm describing.The standard method/'trick' for getting power for the electronics with '2-wire' devices is to stick a small resistor in series with the load - thereby, as you say, 'stealing' a small amount of the voltage, which thej gets rectified to power the electronics. However, that only works whilst there is current passing through the load. Hence, if the load ever gets 'completely switched off', the electronics would lose their power (and therefore not be able to switch the load back on again), unless there was a battery.
Errrm - I'm not sure that it is I who is doing the 'missing'! We were talking about PIRs, not dimmers, and I've already said that there is no comparable issue with dimmers.I think you missed what I'm describing. ... Firstly, consider a standard light switch and light. ... Now replace the switch with a dimmer. ...
I didn't link to it.the one to which you linked says "16 Amp max load regardless of load type including resistive loads and incandescent/fluorescent lighting".
Whoops For "you", please read "333rocky333"! However, my point about what it says remains.I didn't link to it. Nor did I read it.the one to which you linked says "16 Amp max load regardless of load type including resistive loads and incandescent/fluorescent lighting".
Without wanting to get into an argument, you have still missed the point. I introduced the dimmer to explain the operation - bear with me here.Errrm - I'm not sure that it is I who is doing the 'missing'! We were talking about PIRs, not dimmers, and I've already said that there is no comparable issue with dimmers.
With a dimmer, one can do as you suggest (charging the power supply's capacitor during 'off' parts of the cycle), or put a small resistor in series with the load (and do the charging during the 'on' parts of the cycle). What one doesn't need with a dimmer is for the electronics to be powered when the load is switched off. With a PIR, one obviously does need the electronics to be powered all the time - so, in the absence of a battery, the only option is to have a very small current flowing through the load even when it is 'off'.
