help! my dishwasher bosch exxcel auto option doesn't start
Discussion in 'Appliances' started by dam050283, 29 Nov 2011.
  1. dam050283
    dam050283
    29 Nov 2011
    3
    Thanks Received:
    Dorset
    Country:
    Hi I was wondering if someone could help me. The fuse of my dishwasher blew up in the middle of a wash . So I changed the fuse inside the plug and switched it back on the timer was indicating 34 minutes left. When I came back later on the timer was showing 0 but didn't switch off. On the next wash I switched it on and it still showed 0 and didn't start a new cycle. No noise or anything is happening. What should I do?
  2. Sponsored Links
  3. bathjobby
    bathjobby
    6 Oct 2004
    1,200
    Thanks Received:
    18
    Country:
    If its the version with the touch sensitive buttons on the top of the door on the inside, then open the door and check if there is an error indicated on the screen beside the buttons as when there is an error it stays switched on to give you the chance to see what the error is.
  4. dam050283
    dam050283
    29 Nov 2011
    3
    Thanks Received:
    Dorset
    Country:
    nope its normal buttons if i open the door the dishwasher switches off.
    Any other suggestion? lol i thought about replacing the timer panel maybe it just doesn't set any washing program cycle....thanks anyway for taking time to reply.
  5. zipper
    zipper
    20 Nov 2009
    2,789
    Thanks Received:
    506
    Aberdeen
    Country:
    Post the machine "E-number" so we can pin down the model.
    It is laser etched on the door lip.
  6. dam050283
    dam050283
    29 Nov 2011
    3
    Thanks Received:
    Dorset
    Country:
    sorry didn't get back to you sooner. couldn't find it! lol
    The E-Number is : SGS43A18GB/27
    hope that's right. Thanks for your time.
  7. zipper
    zipper
    20 Nov 2009
    2,789
    Thanks Received:
    506
    Aberdeen
    Country:
    It sounds like one of the components has shorted & in all probability damaged your pcb. Follow the (unplugged) cable to where it enters the machine. Check if the the mains suppressor just inside the case has black sooty marks around it. Then inspect the pcb in the RH side of the control panel for signs of damage/blown components.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
