help! my dishwasher bosch exxcel auto option doesn't start
29 Nov 2011
Dorset
Hi I was wondering if someone could help me. The fuse of my dishwasher blew up in the middle of a wash . So I changed the fuse inside the plug and switched it back on the timer was indicating 34 minutes left. When I came back later on the timer was showing 0 but didn't switch off. On the next wash I switched it on and it still showed 0 and didn't start a new cycle. No noise or anything is happening. What should I do?
If its the version with the touch sensitive buttons on the top of the door on the inside, then open the door and check if there is an error indicated on the screen beside the buttons as when there is an error it stays switched on to give you the chance to see what the error is.
nope its normal buttons if i open the door the dishwasher switches off.
Any other suggestion? lol i thought about replacing the timer panel maybe it just doesn't set any washing program cycle....thanks anyway for taking time to reply.
Post the machine "E-number" so we can pin down the model.
It is laser etched on the door lip.
sorry didn't get back to you sooner. couldn't find it! lol
The E-Number is : SGS43A18GB/27
hope that's right. Thanks for your time.
It sounds like one of the components has shorted & in all probability damaged your pcb. Follow the (unplugged) cable to where it enters the machine. Check if the the mains suppressor just inside the case has black sooty marks around it. Then inspect the pcb in the RH side of the control panel for signs of damage/blown components.
