hi
I haven't been able to find much info on how to connect the USB-COM lead( jac-0001) to my premier elite panel to program it.
what is the exact procedure that I need to take to plug the lead in?
I think the steps that I need to follow are...
put engineer hold on siren,
remove fuse from fuse spur,
disconnect backup battery in panel,
then connect USB-COM lead to panel,
reconnect battery in panel,
put fuse back into fused spur,
connect USB-COM to laptop and open wintex?
my system is not installed yet. I'm learning bits that I need for when I do install it.
I'm a novice at alarm systems.
I want to work on the panel when it is completely powered down as in mains off and battery unplugged so that I can take my time and not fry the system if I make mistake.
help will be appreciated
