I'm replacing a BT78b socket, I have a "Can do" attitude that often becomes a "Oh no you can't", so hopefully with your help it can be a "can do" result as I ned the line up and running again ASAP
Hopefully I'm giving you all the info you need to assist me.
The socket is a BT78b image can be found here (http://www.telephonesuk.co.uk/images/small/78A_small1.jpg)
and coming into the back of it from outside comes the cable and orange/green/black/white wire enter this box. (which are now not connected to anything, previously two went to the connections in the box Top row(white=2 and orange=5 I think) and two went to a jellybean connector each with the connection being made with two of the wires from one of the extentions, and the other line went to bottom row Blue=2 and orange =5 again I think)
Now there was/is two seperate phone lines (different numbers contracts) extentions connected to this box both have 4 wires which are the same Brown/green/orange/blue.
What I need to know is where all these wires goto which ones go to which terminals/sockets on the box and wich ones goto the Jellybean connections, and hopefully I'll have two phonelines again by the end of the day.
