I have vaillant turbo max boiler which is leaking water to the pipe that goes through the back of the boiler to the outside of the house. I know it is the pressure relief valve that needs to be changed. I am unsure of the model number. Inside the boiler, it says turbo max GB 242/2-5 R2 and it also says combi turbo max plus 824E. Which is it?
Also, is it easy to change the valve? Are there any instructions I could follow. I asked an engineer on the phone, who I found on yell.com, and he said the valve is £189 plus £70 to install it. He said the boiler needs to be drained of all the water. is this true? I thought he was very expensive.
