Right....
Heating works fine......
Water works fine...
But if the boiler calls for water when the heating is on, the water does not heat up.
Basically we have to turn the heating down for the water to warm up. I have check the mid position valve and it seems that I am not loosing the 240V on the Grey wire that sends the valve to Mid position. There is always 240V on white and grey when heating is on. If I remove the grey wire the valve does move to the Mid position
Any helps would be greatly appreciated
Ian
Water works fine...
Ian
