I have a 4 year old boiler so not too old in a hardwater area.
When using the hot water the boiler will start making a very loud squealing noise like an old fashioned hob kettle, i then have to switch off and let it cool.
The pressure of the boiler also keeps dropping to zero, this was cause by a leaking radiator originally which british gas came out and supposedly repaired (4 times!) I have the BG homecare package which is a total waste of money.
We now have tenants in the property and on BG's last visit they told the tenant it was due to an airlock in the hot water pipe and would be an easy fix.
When i called BG to confirm this, they told me that it was a build up of sludge in the heat exchange and it will require a power flush costing £200-500 but they will have to get somebody out to do a quote. Could it be something as simple as the pressure continually dropping due to a leak causing the noise?
Sorry if that was a bit of a babble, in a hurry!
