Hi All,
My hot water electrics kept tripping out and i have now identified its the electrics in the hot water pump shown in the picture that is the problem.
Looking at the amount of corrosion I assume water has penetrated the pump and causes the short. I will order a new one. A couple of questions:
1) The pump says its a UPS 15-50 "B" 130 but i can only find an "N" 130 for sale - what is the difference between the B and N ?
2) do you think the corrosion on the out flow nut and isolator will clean up ok and if so how - or do you think that needs replacing too?
I will attempt to do the pump change myself so if there is anything you would advise in the process apart from closing the isolators before the work, would be great.
Thanks in advance!
Stew202
Thanks in advance!
Stew202
