help on opening up chimney
24 Dec 2014
Staffordshire
advise needed please. im currently in the process of opening up chimney for a log burner and would like to know if the narrow brick work inside the chimney breast is supporting the corbelling higher up. if not is it safe to take out brick work
Impossible to say without seeing it so I suggest you don't remove it until you have a builder etc have a look and tell you.
