Help outside kitchen drain blocked
17 Nov 2005
Manchester
Hi, our outside drain is blocked, looks like fat, any products I should use please. It stinks
If it's the small outside grilled drain.
Double bin liners over hand and scoop out.
You can buy jet wash attachment for drains off Amazon.
You will need a jet wash to attach it to though
How old is the house?
Is the gulley plastic or fired clay? Clay is more likely to be cracked or broken
Does anybody pour cooking fat down the sink? Stop that immediately. Buy some Washing Soda Crystals (on the Laundry shelf)
Scoop the contents of the gulley out with a large kitchen spoon and you will see if the outlet is blocked or broken
Post some photos.
Chemicals are dangerous and a waste of time, mechanical means is always the best way. Set of drain roads, 4" Plunger on the end and a vigorous plunging will sort most gullies out.
