Posted a few days ago re a solution to my kitchen floor problem. Problem is I think I have a bigger problem than first envisaged. Was trying to level the floor of my kitchen through the hall to the front door as it was originaly a few different rooms and I wish to lay floor tiles.
Initially I thought this could be just a case of patch the low spots and then sling some self leveling over it. However after reading round the forum I decided to check the levels with a laser level and whilst at it I have a cheap damp detector so thought I'd test the concrete that was under the loose/hollow sections of screed.
This was mainly brought on by the musty earthy smell and this morning I noticed a slight amonia type smell as well. Well by the sounds the meter was making it doesn't look good. One section of a brick where there was originally a wall made the meter squeel like a pig and the majority of the other areas were I'd say by guaging the noise as medium damp.
What can i do with this floor? I'm assuming I need to rip up all the screed (which isn't damp just the concrete under it)
I took a datum level from where the front room meets the hall as a start point and measured the levels which I have sketched out using ms paint. (The grey lines represent approx meter squares to give an idea of scale)
I also checked the levels of the exposed concrete which varies from -50mm to as shallow as -25mm from the datum point.
House is an ex authority house and was built in 1950s to 1960s era (can't be exactly certain)
Some pics of the kitchen floor and the levels on top of the screed.
This pic is to show the relation of the floor to the DPC
