HELP PLEASE Vailliant Ecomax 824/2e LEAKING
10 Apr 2012
Glasgow
Hi there guys n gals, :o
Looking for some guideance on the above stated boiler -
Its leaking bably to the outside waste pipe (overflow pipe??)
I am not though losing pressure on the boiler and all seems to be working ok, the heating and hot water.
Advice very much appreciated :cry:
Fiona
You seem to have left the filling valves open!
Better not to touch anything unless you are totally confident of what you are doing.
It will do damage if not sorted out soon.
Tony
Tony
Hi Tony,
I know how to fill and the basic workings of the boiler, the valves are defo closed.
Fiona
If its the copper pipe outside that's leaking and the pressure is not dropping then u have either left the fill taps open or they r broken and not shut properly or the dhw ht exch is split(not likely very rare)
