Can someone advise please on how best to connect my new pump to the bath and basin in this very small bathroom:
As you see the existing supplies are underfloor, but the outlet from the pump will be significantly above floor level. There is very little space to turn the pipework back down below the floor without using right-angled elbows. I'm concerned that such elbows will induce noise and sap flow. Should I be?
Can the supplies come horizontally within the back wall then down to the taps, or will that create airlocks? The back wall is brick/blockwork so would need chasing out. Don't like the idea of pipes in brick wall where they can't be accessed, and perhaps this isn't even allowed...?
I was planning on using plastic but the more I think about it the more I suspect copper is the way forward. Any thoughts on that?
Thank you for all advice. I''ve already got the 'get a plumber in' option in reserve but would like to DIY if feasible.
