Help - Question about Sentinel X200
13 Oct 2010
Buckinghamshire
firstly, please forgive my ignorance if I'm asking something silly..
I'm thinking of applying x200 in the system to reduce some boiler noise. I live in a flat with Vented system. As suggested per instruction, I can just pour the liquid into the f&e tank on the loft. I think the hot water, power shower and CH all use the cylinder.. we also have the f&e cold water from the tank too. (by testing the cold water tap in the bathroom) If I pour the liquid in the tank firstly it won't circulate as water runs through tap and secondly it could be something that I drink? I'm totally confused. Please could someone help me..
That's picture is of a pressured system, so no help to you.
You need to put it in the smaller central heating tank, not the larger main cold water tank.
I would also advise draining a small amount of water out the system first, otherwise the liquid will just sit in the tank and go nowhere.
You may have a vented cylinder, but your heating system may be vented or sealed. It might even be primatic.
A vented heating system will have a small F&E tank. The large tank which stores your cold water is not an F&E tank: it is a storage cistern. Do NOT put chemicals in you cold water storage cistern.
A sealed system will have a (red) pressure vessel, which may be integral to the boiler, and a pressure gauge, but no F&E tank.
Before you go tipping chemicals in tanks, determine what those tanks contain.
