Hi all,
I am extremely worried:
A 'builder' friend of mine has built me 2 walls that join at the ends to use as a planter -rendered with scatch and top coat with a 3-1 mix. The blocks used are 'klinkers' 3 blocks high with no damp course of any type.
I have given this 3 coats of exterior masonry paint which now, after 3 months, has started to bubble vey slightly in very small areas.
The walls are 8" apart on seperate footings and have 12" of dust-free hardcore in the bottom to act as a mini soak away for rainwater. The remaining 20"is partly filled with soil ready to be topped up and planted in the spring.
Will this suffice or should I empty the planter and line the internal sides with say heavy plastic or paintable substance to stop damp coming through the blocks and attacking the exterior render.
They look absolutely superb so I am terrified of them deteriorating over winter to end up having to completey re-render them.
HELP -WHAT SHOULD I DO?
