Help Required - Combi Boiler
11 Feb 2008
Cheshire
Hi guys,
I am hoping to find some help here, i have a halstead ace combi boiler and a digital thermostat.
Basically the system pressue is fine, the setting on the boiler is set to heating and hot water, i have bled all the radiators to ensure no air.
When i turn on the hot tap the boiler fires up as usual and hey presto steaming hot water, the problem i have is when i turn up the temperature on the thermostat nothing happens with the boiler, the green light comes on to register that the thermostat has received instruction but nothing happens with the boiler, it is not locked out!
I have reset the thermostat and turned off power to the boiler and turned it all back on but it made no difference. I cant understand why the hot water works but the heating doesnt.
ANy ideas welcome.
Thanks in advance
Chris
Is the boiler wired to the thermostat?
Did it work last week?
Has anyone ( including you! ) been tampering?
I have not tampered with anything and yes the thermostat box is wired into the boiler.
The problem has now reveresed itself, the heating is working but no hot water, could this mean a problem with the divertor valve?
If so possible costs?
plumber visited and claimed the divetor valve was knackered and needed replacing £200 + labour and VAT
phoned Halstead techincal and they were great told me it would be the diaprahm and the part is only £30.
just need to change the part now :S
lol cheers for that rob.
i'm a firm believer that you get what you pay for (*******s) lol
