Help TRV questions with new system installation
18 Jul 2008
Sussex
I have been getting quotes for a new boiler which needs to be relocated and changed from a vented system to a combi. NB My water pressure is 4 bar and gives 15l/min at kitchen tap and also the bathroom which is mains fed also.
I have some unusual controls in this system.
There are three radiators (lounge, hallway and one bedroom) which are covered with standard radiator covers. Each one has a single port motorised valve that is connected to a roomstat (one in each room) to control the valve to turn it on and off when the temperature set on the roomstat is achieved.
In the new system, i wish to remove these motorised valves but keep the radiator covers. I will be getting a wireless roomstat/programmer (boiler likely to be valliant ecotec 831 or worchester bosch Cdi30)
Will normal TRVs will close down and not heat the room if under the covers? Should i cut the covers down and get TRV's installed so they stick out from the cover or is there another option, I have seen TRV's with remote sensors. would they be my best bet?
Why would you want to keep the radiator covers? They soak up huge amounts of heat, thus increasing your fuel bills. Remote sensing TRVs are your best bet if you don't want to scrap the covers but note that these will also be more expensive than standard ones.
