    Dismiss Notice
help - trying to put new light up but too many wires !
Discussion in 'Electrics UK' started by goalc, 7 Jan 2007.
  1. goalc
    goalc
    3 Mar 2006
    60
    Thanks Received:
    Country:
    I hope someone can help explain what is going on here....
    I am trying to put a new light fitting up in our bedroom, and so took the old one down expecting to find two pairs of wires (each with live, neutral and earth) but what I have actually connected to the old fitting was four sets of wires, each with L,N and Earth (so 12 wires in total). The four earth wires have been connected to form two wires. Also, one of the black wires has a small red ring around it.
    How do I connect this up to my new light ??
    Do I put all the reds together and connect them, and the same with the blacks ? Or do I need to separate these off somehow ? The new light fitting has just got a "chocolate block" fitting for the wires to go into, so I couldn't get all 4 of one colour into one hole anyway.....
    Any advice that anyone can give would be appreciated, as I have all these wires hanging down and obviously need to get them connected in some way tonight !
  2. BigJon
    BigJon
    18 Jun 2006
    449
    Thanks Received:
    26
    Glasgow
    Country:
    The black cable with red mark on it goes in to your L of your new fitting.
    All your reds will go in to a bit of choc block.
    Your blacks will go in the N of your fitting, if they all dont physically fit, put them in choc bloc and take a lead out and in to your N connection.
    Put all your earths in to the Earth connection in fitting, if there isnt one put them in choc bloc
    hope this helps ;)
  3. Sponsored Links
  4. RF Lighting
    RF Lighting
    31 Mar 2006
    19,990
    Thanks Received:
    1,354
    Leeds
    Country:
  5. grantewart
    grantewart
    7 Jan 2007
    6
    Thanks Received:
    Angus
    Country:
    Hi Mate, You have got a lighting circuit wired in whats called the loop-in system. The red (live) wires you will need to connect these into a connector block and the same with the earths and the blacks (neutral) except the one with the red ring round it. This wire is your switch wire coming back from the switch, this will have to go into a seperate connector block which will be the live for your light. You will then need to connect your new light fitting into the connector block.
    ie. Live = Black with the Red ring
    Neutral = Black Wires
    Earth = Green/Yellow
  6. Sponsored Links
  7. goalc
    goalc
    3 Mar 2006
    60
    Thanks Received:
    Country:
    thanks for all the advice - all sorted now :D
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
