Hi
I have 3 queries on new lights I am trying to install.
Firstly, after removing the old light fittings I have discovered that there is no earth wire in the wiring for the lights in our flat. So I have just installed new light fittings with just live and neutral wire, is this safe? The flat was built around 1960, so is this why no earth?
Second - In the hallway the old light fitting had two bulbs in it, each with its own red and blue wire going to each bulb. However the new light fitting has just one socket for a live and neutral, which I have put one set of red and black wires into. The other now 'spare' set of wires I have just taped off individually and are not wired into anything. It seems to work fine, but is this ok?
Thirdly. I'm trying to put a new light fitting in the lounge. It has 1 dimmer switch controlling it. When I removed the old rose, I have 2 cables, each with a red and a black wire in. And another cable with a blue and a brown wire in. I tried putting wiring it, but all I can get is the light to be permenantly stuck on. Any idea what I should be doing, as all that is on the new light fitting is a live, neutral and earth socket?
Cheers if you can help with any of the above
