Help T'shoot a Problematic Smart Switch
30 Oct 2025
United States
I wired a MOES (brand) 3-way smart switch at a desired location in my home and set-up the thing within the SmartLife app. Mechanically, the 3-way switch works as expected; and I can toggle the smart switch ON/OFF within the SmartLife app. So far so good; however...
Two problems within the SmartLife app:
1) the app displays the switch as online but always OFF; and,
2) the app will turn ON the switch as scheduled but it will not turn it OFF when scheduled.
The SmartLife app reports all is good with the switch. Bottom line: While I can control the switch remotely within the app, I have no idea of the status of the lights, and automation is not possible.
I’ve done the intuitive t’shooting whatnots with no change within the SmartLife app:
- confirmed wiring is correct;
- confirmed distance-to-router is not a factor;
- re-paired the smart switch to the SmartLife app;
- relocated the switch to the other end of the 3-way circuit;
- disconnected ground a/o load from the circuit;
- swapped the affected switch with a known-good MOES 3-way smart switch I currently use elsewhere in my home;
- replaced the problematic smart switch with a new MOES 3-way smart switch.
I also connected a different brand smart switch at the same location. Result: SmartLife app displays the switch online but always ON (!), with the same scheduling problem.
Interestingly, when I bench test either smart switch in a 3-way configuration, the SmartLife app displays the correct ON/OFF switch status and ON/OFF scheduling works! This confirms 1) the switch works properly; and 2) the SmartLife app is getting accurate status information from the switch. This also suggests the hot a/o neutral wires are the culprit? ...like maybe noise across either/both conductors causes a status sensing issue that the switch’s CPU broadcasts as errata to the SmartLife app? I don't know how to test this theory or how to detect noise in the 3-way wiring.
SmartLife and MOES email support provide zero useful assistance with this matter so I'm on my own here. Hoping someone reading this post can offer some insight.
I had a problem with Energiser app, it seems it is Smart Life, just a name change, once I reprogrammed them to Smart Life, all worked OK. Not a clue what is sold in the USA, but you may have ended up with two apps fighting each other like I did.
