Help : UPVC Flag hinge compresson adjustment
30 May 2006
Yorkshire
Hi
My double glazing doors leaks like hell, but open and close fine.
I think it just need the hinge side compression adjusted.
It's got 3 way flag hinges but i can't work out how to do this.
There seems to be a plastic cam with an Allen key slot, unfortunately this doesn't want to turn and I can't find any grub screws or anything that lock the plastic cam in place.
Here's a pic:-
Any ideas ?
thanks
Looks like you have the door off already so nice easy job.
There should be a line on the cam, Make a pencil mark on the hinge where it points to now.
If it wont turn then just knock it down and out. Have a look under it to see which way it needs to turn and then tap it back up and in. Set all 3 hinges the same.
Make sure you put the top caps on before you rehang the door as these are what stop them turning freely.
Many thanks Gazman 16 :D
Had a stinking cold on saturday night and ended up with a sickie from work today. felt a little better this afternoon so gave it a shot.
I had to tap the thing out and it was a bit fiddley to get it lined up correctly when refitting. But i belive it's worked great .
