Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
just after a bit of advice on using solderless fittings, how much solder do you add to use the fittings that dont have a solder ring already in them also how do i get the solder run upwards say when im soldering the bottom joint of a T joint. thanks
clean the pipe and fitting with a cleaning pad NOT steel wool, apply a tiny amount of flux to the pipe NOT inside the fitting, heat the pipe for approx 9 seconds, remove flame and apply solder (this is the bit that comes with practice) the trick is to use the heat from the pipe NOT the blowlamp to melt the solder, apply the solder at the back/bottom of the fitting and watch for it running round to complete the joint, as a rough guide use 15mm of solder for 15mm pipe etc, bend the solder at the end then apply till the bent bit is gone so you dont add too much, the rule of thumb for this is practice, practice, practice some more then practice, then it is easy
Good on you for using end feed! Not even some professionals use End feed.
As suggested above a clean pipe is vital. Apply flux to end with a brush, not too much, the more you put will make it more difficult for the capillary action to take place. Put the fitting on and warm the fitting mainly not the pipe but apply to pipe sightly. Tap some solder to the joint, experienced plumbers will know when it is hot enough by the colour of the flame. apply a bit of solder and you will see the solder get sucked in by the flux. Practice firs to get good at it.
If the metal is clean and fluxed, and the joint is hot enough to melt the solder when you apply it, but not so hot that the flux has burnt away, capilliary attraction will draw it uphill into the joint.
Add too much solder, or overheat the joint, and gravity will take over, allowing molten solder to drip off the pipe and drop straight down a lace hole in your shoe.
I stand corrected I know cleaning pads are available but some plumbers use steel wool The only way to learn is to ask so!!!! why not steel wool? I'm not being sarcastic i'm just trying to learn
no silly questions, only silly answers is my motto, if you use steel wool you can get tiny fragments between the pipe and fitting which can hinder a good joint, or they get trapped inside the pipe and can rust and cause probs.
Some use steel wool cause that is the way we were taught in black and white days and we are a bit slow to embrace these new fangled inventions
i commented approx 9 secs of heat and someone posted depends on flame and pipe dia which is true, but it is approx and a guide only and i assumed the original post was based on domestic pipework rather than 54mm, which does take a bit more care, but try it and decide for yourself, you will find 9 secs is not far away
