Have just had a new V4073A 3port valve fixed, CH and HW work fine, also when both are on together, they also work fine, the problem is when all is switched off at the programer, the valve is still energised, and the grey wire to the valve is still alive, if I remove the grey wire from the joint box, the valve runs back, then if i put the cable back in, it does not energise again untill the next time the heating switches on again, but then is stays live again, till i remove and replace the grey wire from the valve,any help would be great.
thanks billjohn
thanks billjohn
