Hi..
Please confirm if i'm understanding this correctly. If I want to drain down a sealed system (c/heaating), I turn off boiler, then drain down from drain off cock which I run a hose from to a outside drain.... Once i'v finished altering pipe work and adding replacement rads, I then fill system back up. To fill up I use the filling loop.
Question: Boiler is in the downstairs kitchen and expansion vessel is on top of hot water cylinder upstairs in a cupboard. Kinda confused how I check system pressure?? If its a combi do I ignore the expansion vessel upstairs and go by whats on the boiler pressure gauge?
Can anyone help?
Thanku in advance any help would be appreciated..
Can anyone help?
