help with ceiling fitting-not my fault this time
k3z
18 Oct 2007
Worcestershire
Hi all,
after the help I got with my last issue,I thought i would ask for assistance with this one.Below is how my living room rose looks with the standard fitting.Im a bit confused by this as when i wired up the one for the dining room i used the outside L & E to wire up,but these are on the inside ones.
here is the pic
http://s242.photobucket.com/albums/ff190/k3zza_2007/?action=view&current=rose.jpg
This is the new fitting that i want to put up,but am unsure as to where the wires will go as there is 2 extra wires on this one.
http://s242.photobucket.com/albums/ff190/k3zza_2007/?action=view&current=fitting.jpg
Any help greatly appreciated,many thanks,kez...x :)
From the fitting
Brown wire to the single black ( switched live, should have a red sleeve on it )
Blue wire to the two blacks ( neutrals )
The two green/yellows to the terminal marked E with the green yellow from the cable
Nothing from the fitting connects to the three reds ( live loop )
