Help with confusing new flat heating system
9 Sep 2013
Surrey
Hi All,
I have just moved into a new flat and it has avery unfamiliar heating system and no manuals to be found.
There is a dimplex RXPW4 in the cupboard which I think controls the 3 mini heaters but I haven't set this up yet.
There doesn't seem to be a timer/controller for the hot water, just 2 switches for the heating cylinder which are always switched on. I have hot water but I am worried it is constantly on and heating the water and Im going to get a huge bill or the thing will explode.
any ideas?
Jon
What you have looks like a direct unvented cylinder. The bottom element is for general use and the top one is for a "boost" should you need hot water quickly.
If there are no timers anywhere for this then keep the bottom element switched on and the top one switched off unless you need a quick boost of hot water should you run out.
Generally the bottom element is on Economy 7 but that depends if that tariff is available to you?
If you are on a single rate tariff then it would be possible to put the bottom element on a timer if needs be.
As for the heating, the controller that you have controls the 3 "zones" that you have.
The set up instructions can be found here:
http://www.dimplex.co.uk/assets/kb/operating_instructions/0/RXPW4_Instructions_Issue_4.pdf
Hope that helps
Jon
Sorry, should add to the that.
It wont explode being left on but you will get a higher bill.
Is it rented or bought?
