HELP! Day before Christmas Eve, and a leaking compression joint on an isolation valve that connects the feed pipe to a radiator. Carpet soaked, people coming...
I've tightened the joint as much as I dare and it hasn't stopped dripping. Maybe now overtightened?
I can't disassemble and try a new olive, because the isolation valve seems not to be working (or it does work and the drip is from water from the radiator side?
And I can't drain down the system as guests are from overseas, with little babies, and they need to be warm!
Is there a product (likely to be available before shops close on Christmas Eve) I can wrap around the fitting, or which will stem the drip, until I can get a plumber in after the hols, or tackle myself when my guests have all gone?
Most repair suggestions assume turning off the water first, which cant do in this situation!
