Hi folks
Moved into my house a while back and the PIR/outside security lights were working OK.
There are two lights and one PIR in between them.
Then the PIR went so I've tried to replace it. Stupidly(!) I didn't check the wiring of the PIR I was removing, as I thought it would be a simple replacement.
So I connected the neutral, live and earth - all the while wondering why there wasn't two cables, one the feed and the second going to the first light (which I assumed would then go to light number two).
Anyhow, I wired it up - and the lights are on permanently, unless I switch them off. As a guess I changed the live to L1 - same thing.
So I had a look in the garage loft and found four cables all meshed together in electrical tape, presumably around electrical connectors!
So it seems one cable is the live feed, one is light number one, one is light number two and the other goes to the PIR.
Is that not a strange way of doing things? Doesn't it also mean that the lights will always be on permanently if the live feed is switched on?
Not sure what to do so any advice much appreciated!
Ben
Ben
