help with pump connections!!!!
19 Mar 2005
Hi there i need to swap an old water circulation pump for a new one,trouble is the old one has 4 wires coming into it,white/yellow/blue and earth,the new pump only has provision for 3 wires live/neutral/earth,can i still swap it over?what are the yellow /white connections for?any help would be much appreciated
thanks
lewis
Little more info please ,:
voltage maybe good start - you do have equipment to test voltage ? :roll:
you could always stick your --nah
yes 240 volts is required for the new pump with 3 connections and that is what i have on the white and yellow lead of the 4 core flex obviously the blue is N and the green&yellow earth!
AT WHICH 2 POINTS ARE YOU TESTING FOR VOLTAGE ?
correction sorry its late,i havent yet tested the voltages at the end of the 4 core flex i shall tomm,do you know what i should have and ultimatly if i can use this 4 core to connect into the new pump,it is friends problem so i dont hve all the info/instructions here so thought id ask an expert if he could at least let me know if it is possible,do you know what the white and yellow are? and if i can do it,if you cant answer then ill get more info tomm ie voltages etc if you require
thanks
where did the 4 wires connect into the old pump ?
More important than where they went in the old pump, What do they connect TO in the old system!
what old system chris ?
think before you type :D
what old system ?
old pump not system ,------ think before you type !!!!!!
:shock:
mucky !!!!!!!!!!!!!!!!! are you trying to correct me ?
at what point did you view old system ,/ ? on the forum
