Help with texecom elite 48
25 Oct 2016
I’m programming the above and got a bit stuck
The entry and exit timer seems to be on final door close is there somewhere in the program that will just do the time and also is there somewhere a program to turn off the banner when set so I know it’s set thanks
Cheers for that do you know if there’s anything on the banner goes off when armed and do these tags work with this system tried but not getting anywhere it says present tag now
What’s that fob from ? Other system / access control ? ....the only fob s that I know to work ( seen ) are ACT access fobs
If it doesn't register the tag isn't compatible, many of the kits come with a pack of 5 prox tags.
Texecom tags don't usually have any printing on.
So as pointed out where has the tag come from?
Think I completely messed programming up ok so yesterday was only using zone one to test
Today when I’ve powered back up zone one would trigger and let me turn off (but don’t have to scroll through) to reset
However when I go through zone 1 on entry and walk through zone 3 it triggers alarm which I want it too but won’t accept code it asked for tag when I did press rest it says contact arc ????
Sorted the tag one user 1 program time lock it seems to reset now without going into service but still don’t have to scroll through events to reset ?
