Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Is this a sawn size, nominal prepared size or exact finished size?
If sawn you should have no problem getting 38x50 both treated and untreated. If finished size then you will have to get it done for you, if nominal ex 1 1/2"x2" then this is readily available but would give a finished size of approx 32x44mm.
