HELP!
2 Sep 2008
Hampshire
i have just screwed though a live wire (of the ground floor lighting circuit)
i have repaired a bit of plaster around the light switch earlyer today, and the switch needed changing for a new MK one, so i did it. after this i screwed the switch back on, but leaving a good few mm air flow for the plaster.
i have just gone to screw the switch on fully, but as doing this i managed to nick the sheath of the cable behind the screw. and oviusly it arced, and tripped the mcb(thank god!)
i have made safe, by keep the ground floor lighting off, and putting a bit of insulation tape around the nick(this is a 2 gang switch, the switch which has gone is a 1 way)
my question iss.. is there any way to fix this, with out replacing the cable.
i know this is my fault, as i was not paying enough attention and didn't check for clearance behind the screw. learn from your mistakes!
please respond.. :)
How mauch wire is there to play with? You may be able to extend it by using a small of terminal block (choc block) in the switch back box and add a short piece of wire.
Take a picture and post it on here.
not much to be honest, alot less than all the other wires in the box :S so possibly this has happend in the past and the wire has be cut and shortend.
i will post a picture tomorow when i get back at it, and when theres a bit more natural working light :p
if the copper isn't damaged then you could apply some heatshrink to restore the insulation..
heat shrinking could be a possibility, but the problem is i don't have any tubing or hot air gun.
i could do the previous suggestion, from taylor. but would this be deemed safe,
another thing i have thought of, could the arc flash have caused any mechanical damage to the switch?,
thankyou both.
i will post an image in a bit
update: i have fixed the light switch, there was a break in the copper wire were the arc has happend. which is why the switch would not work. i have stripped the wire back to clean copper. it now works fine. although i may need to extend the wire becuase as i was screwing the faceplate back on (making sure for clearence this time!! :oops: ) the switch is now wonky... as the wire isnt long enough.
i have to say i am pretty annoyed at my self for this, as this is the first time i have ever gone though a wire, in my many years of working with electric.
sorry, i dont feel the need to post a picture now.
thankyou all for your help :D
Extend it how TTC suggests, with a choc block. This is fine as it is concealed in the backbox out of harms way.
I wouldn't worry - you'll always check in future so it shouldn't happen again!
yep, thanks i have done that and it now all works
yeah hopefully i would of learnt from this lesson :LOL:
thanks everyone
Have you tried pulling the cable for some slack?
Most houses are wired using conduit and sometimes a small loop of slack is left above (or below) for such problem.
no i havent tried and im nto going to. because i know this house isnt wired liek that. the cables are held onto the wall with nails. (the head of the nail resting on the cable)
but it is sorted now :)
whats that face for BAN?
Just a wry smile at you saying that you've been doing electrical work for many years but you don't have basic materials and tools like heat-shrink tubing and something to make it shrink...
